Use the following procedure to configure and enable IPsec for the OSPF virtual link.
IPsec is disabled by default.
Configure the OSPF virtual link.
Create the IPsec security association.
Until you enable IPsec on both sides of the virtual links, the links cannot exchange OSPFv3 control messages, and the system drops OSPFv3 exchange packets.
You must disable IPsec before you can perform virtual link policy configuration changes.
- Select IPSec.
- Select the OSPF Virtual Link tab.
- Select Insert.
- Specify the area ID.
- Specify the neighbor address.
- Complete the remaining optional configuration.
- Select Insert.
OSPF Virtual Link Field Descriptions
Use the data in the following table to use the OSPF Virtual Link tab.
Name |
Description |
AreaId |
Identifies the OSPF virtual link area. |
Neighbor |
Identifies the OSPF virtual link neighbor. |
SAName |
Links the security association to the OSPF virtual link. |
AdminStatus |
Enables the policy. The default is disabled. |
Action |
Configures the action of the IPsec policy under the OSPF virtual tunnel to one of the following:
The default is permit. |
Direction |
Specifies the direction you want to protect with IPsec:
The default is bothDirections. |
SrcAddress |
Shows the address of the source interface to which the policy applies. |
DstAddress |
Shows the address of the destination interface to which the policy applies. |
LinkID |
Shows a unique ID for the OSPF virtual link. The default is 0. |
IfIndex |
Shows the interface index to which OSPF virtual link the policy applies. |
OperStatus |
Shows the operational status of the link, either up or down. The default is down. |
